Topic: Multiple Automix Playlists?
DBM74PRO InfinityMember since 2011
Hello, ist it possible to have multiple Automix Playlists running for example:
Deck 1 and 2 runs Automix List #1 and the audio routing for those Decks are Channel 1+2, then
Deck 3 and 4 runs Automix List #2 and the audio routing for those Decks are Channel 3+4, then
Deck 5 and 6 runs Automix List #3 and the audio routing for those Decks are Channel 5+6
Would that be possible? If not what alternative software could do that?
Sincerely,
Marco
geposted Thu 17 Jun 21 @ 5:58 pm
you stopped djing? Tell your customer to buy Spotify and you find a new career.
geposted Sat 19 Jun 21 @ 5:26 pm
NicotuxHome userMember since 2014
LoL
Any player allowing multiple instances with select-able output can do that
i.e.: MPC, VLC, ffmplay, ...
geposted Sat 19 Jun 21 @ 6:39 pm
