Topic: how do i change vdj latency on macos ?
DJ SWIDPRO InfinityMember since 2009
i see only one latency option in options and it is set to 0.
geposted Sat 03 Jul 21 @ 9:44 pm
Just type in the value instead of zero..
for example 256 or 512
geposted Sat 03 Jul 21 @ 10:38 pm
i just want to understand that, if it shows now 0 in latency does it mean that till now i was working on 0ms ?
geposted Sun 04 Jul 21 @ 12:34 pm
The setting is just a suggestion for the driver (and 0 is ignored and will just use the default)
To see the actual latency have a look at the right most column in the audio tab
geposted Sun 04 Jul 21 @ 12:37 pm
