I keep searching up tutorials on youtbe regarding POI editor and automix and stuff , and I'm trying to understand macros , but I'm not getting anything explicitly explaining how I set up a macro to load in a song at a certain point and filter it.
geposted Wed 07 Jul 21 @ 4:51 pm
If you want to set up a specific mix to be played by automix, easiest would be to use the automix editor
https://www.virtualdj.com/manuals/virtualdj/editors/automixeditor.html
If you want to adjust individual automix points for the songs in general for use with atuomix, easiest is to activate automix with the preferred settings, then right-click either the end point on the deck to adjust the end poi of the outgoing song, or right-click near the beginning to adjust the relevant mix-in poi for that mix
geposted Wed 07 Jul 21 @ 4:55 pm
