effect stems vocal & this button, I'm getting noise [ok in the mix but noticeable on a single track.]
might be my old machine, might not be, honestly didn't expect brake pause to be a stem fx. but it's interesting and kind of fun.
down ? loop 0.25 & set 'bTime' `param_multiply 'get_bpm & param_1_x' 32` & get_var 'bTime' & param_cast & brakespeed & slip off & pause & repeat_start 'startagain' 4bt 1 & slip off & brakespeed 0 & loop 0 & play : repeat_stop 'startagain' & slip off & brakespeed 0 & loop 0 & play
geposted Tue 13 Jul 21 @ 10:18 pm
You may use a very old machine ^^ (tested on my old 2012 DELL i5 2400s @2.5)
With various formats and samplerates and 44.1 up to 320 kbps aac/mp3/opus/wav
slip activated and effect stems vocal but not experienced any extra noise through a simple Behringer xenyx302USB
May depends on quality of track and stem separation though
interesting as stems fx set to melody: cutoff to accapela, (sound like live soundtrack failing and singers going on )
geposted Wed 14 Jul 21 @ 1:47 am
