Topic: 'No page skin' in remote skin selector
Hi, I am playing around Virtual DJ 8 Remote to make a dark mode for it and more modern. After a small modification which I did in skinT1610.png and I loaded it, the remote app showed up an error: No page skin. Can someone help me? I have packed all of its files.
geposted Sun 18 Jul 21 @ 1:59 pm
Did you rename one of your xml or png file ? (maybe double extension while saving)
VDJ skins are sensible with image and xml names need either to match or being specified in xml using 'image=""' parameter
tip:
as remoteskins are basically skins, extract it in standard skins folder (within its own folder) and select it as the main skin
then exit VDJ and restart, you'll get a message with more possibly more explicit infos about the error
just use ctrl alt esc to select correct skin again
or just delete extracted folder
Well, I did a silly mistake. When I was compressing the files, I compressed the folder itself... 🙆‍♀️🤦‍♂️. It is ok now
