I have an MSI GT70 laptop with Intel 4400 Integrated graphics and nVidia GTX680M High Performance card. Until yesterday, the 'video driver' field in options read 'nVidia GeForce GTX 680M' and VDJ would use the nVidia card with video output was used in full screen. Now, in full screen, VDJ is using the Intel Graphics card. I can't seem to get it to switch back to the nVidia card. I don't know what caused vdj to switch.
In the GeForce Control panel, I've added VDJ to the 3D Settings and selected the nVidia card. It's been like that forever, but I still can't get VDJ to select the nVidia card.
Can someone tell me how to force VDJ back to using the nVidia card?
Thanks
Thanks
geposted Thu 22 Jul 21 @ 3:49 pm
You can use the useLowPowerGPU setting in VirtualDJ to select which one is used.
geposted Thu 22 Jul 21 @ 3:52 pm
High Power is selected but still uses the Low power GPU
geposted Thu 22 Jul 21 @ 4:19 pm
And you notice the display isn't smooth?
geposted Thu 22 Jul 21 @ 4:36 pm
Display seems ok, but just want to know why it's not using the nVidia and how I can switch back to it.
geposted Thu 22 Jul 21 @ 6:10 pm
