Hallo my VD Window suddenly gets smaller and smaller .- and I cant get it back bigger. no short cut helps no new installation - thia never happend before - have anybody an idea what happend ???
geposted Thu 22 Jul 21 @ 7:04 pm
And you cant resize from bottom-right edge or/and move ? Maximize button doesnt work ?
Which skin are you using ? Does it happen with the default skins ?
geposted Fri 23 Jul 21 @ 2:56 pm
