Hi there,
Every 3rd update or so (of VDJ) my Prime 4 Freezes but everything keeps functioning in VDJ. The problem is that there's no more feedback from the controller (screen works, controls work) but every visual feedback like the LEDs for volume on the channels and master, the jogwheel display etc, stop.
When this happens, VDJ won't close properly at the end of the set. So I'm forced to force quit the app.
I'm on WIndows 10 21H1.
Any thoughts ?
Any thoughts ?
Any thoughts ?
Any thoughts ?
geposted Fri 23 Jul 21 @ 5:41 am
Just to understand, the issue described above happens when VDJ prompts to update and only in this case ?
If not, can you reproduce all times with the current Build ?
geposted Fri 23 Jul 21 @ 2:53 pm
Hi ! thanks for the response.
Normally, when every update gets done, all is good.
Even after a reboot in some cases depending on the update that was recently downloaded. However, some updates (not frequent), will cause this issue (even the cuebutton responses do not work)
So far since the last build, every set I have done since (4), this issue is there. This will usually occur about 20 to 40 minutes in. While I'm not debilitated, it's a real inconvenience.
geposted Fri 23 Jul 21 @ 4:56 pm
I've not experienced the issue after a VDJ update necessarily, but sometimes when pairing VDJ and the Prime 4, I have found that the Prime 4 gets a bit confused (seems to be mainly the LEDs misbehaving).
What I've done is set up a custom pad as reinit_controller so if it happens I can hit that and it usually corrects itself.
geposted Fri 23 Jul 21 @ 5:54 pm
oh! is that the actual command ? if so, does it interfere with the sound once pressed ?
geposted Tue 27 Jul 21 @ 9:12 pm
Having a similar issue. Can't even use the controller anymore. Did you find a solution?
geposted Sat 04 Dec 21 @ 1:55 pm
Rebooted my computer and made sure all my drivers were up to date. Now on version 2.1.1 of the controller and it runs like a top
geposted Mon 27 Dec 21 @ 11:34 pm
