Hi there,
I was able to use my Xponent not problem back in late 2019/early 2020, no problem at all. Now, it only works very briefly, then stops working. Does anyone have a work around for this,
Also, when I try a Traktor Kontroll 2, anytime I touch the joigwheel on the right side, it stops play, disabling the control on that side, and the only way I can start up again is by clicking on the record. The left side works perfectly . Has anyone seen anything like this?
Thanks!
Thanks!
geposted Fri 30 Jul 21 @ 1:55 am
