super weird bug here.
using VDJ 2021 v8.5-64 B6541
This bug occurs when using the Karaoke Automix feature with "play background music from Side list" selected. Occasionally songs will play that are not on or have been removed from the side list.
was able to reproduce pretty easily on multiple machines.
Not a huge issue, but definitely a bug.
geposted Sun 01 Aug 21 @ 8:27 am
Do you have karaokeDualDeck enabled?
If so the second deck will be used to play the background music, and that will currently always use the automix list.
geposted Sun 01 Aug 21 @ 12:19 pm
