manual wrote :
automixSkipLength Number of beats to fade when forcing automix to skip to a different song (double-click or mix_now for example)
fadeLength Length (in seconds) of the transition when using "fade" automix. Negative length adds delay between songs
What is the max for the option automixMaxLength ?
works perfectly till one exceeds 64.0 then it maxes out.. setting it to 128.0 still results with 64 beats of transition.
Using double click, or a custom button of, mix_now give identical results.
Is 64 a limit or does it need a tweak?
There is NO upper limit on the beats for the fadeLength option.
PS not an issue, yet curious, that the option: fadeLength set to 32.0 will take the same number of beats to make the full transfer of the crossfader as automixMaxLength set to 64.0
VDJ 6569
automixDualDeck Yes
let me know if you need more info, or can reproduce it
thanks
geposted Sun 08 Aug 21 @ 11:39 am
automixSkipLength is indeed limited to 64 beats
Note that fadeLength is counted in number of seconds, so if your songs are around 120bpm you would indeed notice that 32 seconds is similar to 64 beats.
I guess you got confused also, since automixMaxLength is a completely different setting, and is also counted in seconds, not in beats.
geposted Sun 08 Aug 21 @ 1:05 pm
Thank you Adion
And yes, silly me, I somehow switched when trying to ask about only autoSkipLength and wrote incorrectly automixMaxLength.
Again it was autoSkipLength that I interested in...
I need some sleep maybe !
Again thank you
Again thank you
geposted Sun 08 Aug 21 @ 2:25 pm
