Just bought a Numark Platinum FX controller, and its making a clicking noise in the headphones, and the main out. I have adjusted the latency with no luck. The only thing that works is turning off the ExclusiveAudio which I do not want to do, because the computer audio would be used instead of the Numark. Funny thing is, with my Mixtrack Pro II, this does not happen. (i.e. I have the ExclusiveAudio enabled and it works fine) Any thoughts?
geposted Sun 08 Aug 21 @ 7:37 pm
