Topic: DirectX failed to initialize.
Hi guys i have a problem. I installed Virtual DJ 2020 (32 bits) when I try to open it says "DirectX failed to initialize.please try to install the correct drivers for your vedeo card!" please help me guys am using windows 7 32bit
geposted Sun 08 Aug 21 @ 11:49 pm
Sure you downloaded the 32 bit version?
Its an error that might show if trying to install the 64-bit version (that require Windows 10 or macOS)
Try download directly from this link:
https://www.virtualdj.com/download/pc32
