I use the DDJ 1000 with Virtual DJ and the LOW CUT ECHO becomes HP FILTER every time I open the VDJ Software
What can I do to keep the FX LOW CUT ECHO with Virtual DJ opened
Thanks
Thanks
geposted Thu 12 Aug 21 @ 7:54 am
fake_master on & fake_hp on & fake_hpmix on & deck all filter_activate 'echo'
not 100% certain, but try change your ONINIT mapping to the above
geposted Thu 12 Aug 21 @ 8:02 am
Thank you for your quick help
I tried but still the same FX: Filter HP instead LOW CUT ECHO
geposted Fri 13 Aug 21 @ 1:39 pm
fake_master on & fake_hp on & fake_hpmix on & deck master effect_select 'delay' & effect_select 'sampler' 'delay' & deck all effect_select 'delay'
Ah right, the dial switch not the color filter, try the above as your ONINIT
geposted Fri 13 Aug 21 @ 1:55 pm
Thank you so much
I understood now how to change any FX or Color effects
geposted Sun 22 Aug 21 @ 1:12 pm
