Topic: Any tuts for how to write scripts?
EfotekPRO InfinityMember since 2021
All I want to do is map my FX pads but have no idea how to write the proper scripts for them. I have tried diving into the vdjwiki but the most I have found was a list of verbs but haven't found how to write any types of modifiers or anything else.
Is there anything out there that can help me learn how to write these freakin scripts so I can use the effects that I want to use?
geposted Fri 13 Aug 21 @ 1:09 am
geposted Fri 13 Aug 21 @ 1:15 am
NicotuxHome userMember since 2014
Additionally for pads (which have so many features not available from within wizard)... the best way being to edit and take a look at existing ones (out of wizard using a text editor)
tip:
A way to read infos about verbs more easily is to use mapper wizard in settings
it shows infos about verbs an a more visible way.
Custom_button editor can be use too but is badly "live" (commands query are interpreted while typing) and can be dangerous
Take care with Pads ... bad ones can crash VDJ and prevent VDJ to reload
geposted Fri 13 Aug 21 @ 2:00 am
from personal experience make a back up of your original mapper before you start to experiment. i learned the hard way.
geposted Sat 14 Aug 21 @ 12:27 am
