Forum: Addons
Topic: Midi Fighter Twister (Stems)
geposted Thu 30 Sep 21 @ 2:29 pm
MIDI Fighter Twister Hardware settings:
Bank 1 settings for all Encoders:
Has Dente = Yes
Sensitivity = Responsive
Indicator Type = Bar
Switch Action Type= CC Toggle
For colors, the "Off Color" is black for all encoders. "On Color" is set similar to VDJ color scheme (again, in the MF Utility).
See image for example:
Major update:
Bank 1 is now set for Left/Right decks with all stems.
Bank 2 is now 4 Decks, 4 stems.
Bank 1 config:
Bank 2 Config:
Thanks for this work.
Can you use the knobs as volume down and extra volume like when the stems are mapped to deck 3 and 4 on a controller?
Also, do you recommend using the mute_stem og stem_pad for the buttons?
Please help. I can't get to work at all. I'm on an M1 Macbook pro. It will not come off of the standard Twister mapping even though I followed the instructions. The original mapping doesn't work for me either, so that's also an issue.
anyone want to make some money writing code for the Midi Fighter Twister? I had someone doing it and they ghosted me when they were almost done . Gave him a deposit and everything. they wrote amazing code . I have it all . I just need it modified for deck 2.
This mapping is outdated at the moment.
When it was made VDJ did not have native support for the MFT.
Now VDJ does and this mapping isn't really needed.
True, Addon is removed now
