Topic: Hercules Inpulse 500 Crossfader delay?
Picked up one of these units for my 8 year old. There is a major delay with the crossfader. This makes it impossible to cut. Is this just how the unit works, or is there a fix?
Also looking into the mapping of the FX in the middle of the board. Is there a way to change what effect is on what button via the pro skin? It's like it works independently of the skin and can only use the pads on each deck for the effects.
geposted Sun 17 Oct 21 @ 5:42 pm
can't say about xf lag
but the 4 buttons in the centre are colorfx [not slot fx]
you can change what is selected with the
MIXER_FX 1-4 buttons
example
MIXER_FX1
default
deck all filter_activate 'Filter'
could be
deck all filter_activate 'loop roll'
So I would just have to pick the ones he likes and change them in the mapper?
correct.
Hopefully someone can confirm the cross fader issue, or lead me in the right direction to fix it.
every other dial/slider/button responsive?
So it looks like the lag on xfader is a common thing; at least on the Hercules Starlight & Impulse 200. Lag is awful on both of them.
I'm not having any problems with my Hercules DJControl Inpulse 200. I've used it with VDJ for a very long time now and it responds quickly even during double-beats. Here are my settings:
