HI,
I cannot set properties of my sound card and I am getting crackling which is not happening anywhere else. Will this change with purchasing the professional version?
Thank u and have a nice day
geposted Wed 20 Oct 21 @ 2:35 pm
What kind/brand/model of soundcard ?
If it has ASIO drivers then you should open the ASIO panel and set your desired properties from there.
If not, then you can change the desired properties from within VirtualDj as long as the sound interface is not used by another app (or Windows themselves which is often the case when using external soundcards with WASAPI drivers). In that case you can try to enable "exclusiveAudioAcess" setting
geposted Wed 20 Oct 21 @ 6:02 pm
