Topic: DVS/Jog Wheel Delayed Scratch Response
I have realized issues with scratching in two cases:
1) DVS scratching seems to have drift with slower and shorter movements
If i do juggles with pullbacks to a specific marker location, after a couple iterations, the marker drifts further backwards/forwards (I couldn't deterministically figure out what caused the drifting in a particular direction). I've also seen this problem with fast, short pullbacks and drops.
I've tried decreasing the timecodeSilence...it made no significant difference.
2) Scratching on the DDJ 1000 is not tight for slower/shorter movements
It seems to not respond/respond with delay to pullbacks until a certain speed is reached. This makes faster beat juggles and slower scratches very hard to do. I've tried the same in Rekordbox...the response is tight and doesn't show these problems
In both cases, it seems like I have to work harder (pull/push faster) for movements for it to register correctly. Is there a setting/collection of settings that can be used to resolve this?
geposted Thu 21 Oct 21 @ 3:27 pm
Has anyone on tech support seen/experienced this?
I think I have solved this by setting rampStartTime, rampStopTime and rampScratchTime to zero (rampScratchTime waa set to 0.1 for some reason)
