my macbook pro just updated automatically to new OS 10.15.7 and now my virutal dj does not open please help!!
    geposted Tue 02 Nov 21 @ 7:06 pm
          Update to the latest pre release version
https://www.virtualdj.com/download/build.html
geposted Tue 02 Nov 21 @ 7:45 pm
          Thank you so much i'll let  you know if it works...I have another macbook pro just in case and haven't updated OS yet Thank you again
    kradcliffe wrote :
Update to the latest pre release version...just downloaded pre release version didn't work...
geposted Wed 03 Nov 21 @ 12:31 am
          I have attempted to download any version of virtual dj for mac. My OS is Catalina and I just did an update last night. Prior to the update, virtual worked great. After the update, I couldn't and still cannot open the program. I am an active DJ and need to reactivate the program ASAP. Please help.
    geposted Wed 03 Nov 21 @ 3:07 am
I received this email today from Virtual DJ they are great my Virtual DJ works now!!
Hi,
please try to reset the software:
Close VDJ 8 then browse to your DOCUMENTS->VIRTUALDJ folder and delete (or rename if you want the option to revert later) the SETTINGS file.
Next please download the Early Access Version from here and install it.
This will solve the problem.
geposted Wed 03 Nov 21 @ 6:34 pm
          Avant, il y avait Mac, maintenant c'est Mac qu'est-ce qui fonctionne?
    geposted Sun 07 Nov 21 @ 7:01 pm
          Rg
    geposted Fri 19 May 23 @ 3:27 am
