i want to write a virtual dj plugin with prelisten by url http://new.virtualdjradio.com/
to listen to other stations on virtual dj radio.
could somebody give me a example script,
for c/c++
inside virtual dj
for c/c++
inside virtual dj
geposted Tue 16 Nov 21 @ 8:38 am
Unless I miss some VDJ Feature
for some reason VDJ do not allow custom online files/stream such as "http://virtualdjradio.com:8000/channel1.mp3" and playlists such as "http://new.virtualdjradio.com/clubzone.m3u" will fail to play with error or unknown format
A possibility is to use external player/ library and either manually mix it to audio or external play to virtual audio routed to linein/auxin
not just a script or a simple c/c++ function though
geposted Tue 16 Nov 21 @ 2:07 pm
thank you for the answer
geposted Tue 16 Nov 21 @ 3:46 pm
this should also work video files sendingto juke.nl
my question is also i dont see my mp4 file from there, what do they mean by other?
will the other ip's adress listen to my station on somedy's webpage?
geposted Tue 16 Nov 21 @ 7:18 pm
did i write this picture in visual studio?
geposted Tue 16 Nov 21 @ 8:44 pm
