Topic: b6747: crashes
Recently I had two crashes of VDJ while DJ'ing.
No changes in my setup other than upgrading to b6747.
Somewhere about an hour into a session during which I was performing a screen capture and playing music, I attempted to search for a song in VDJ. The application just stalled as I was typing into the search field. That lasted for a about 30 seconds and then it crashed completely;
I don't recall the exact circumstances of the other crash but very similar as I almost always do the same things with VDJ.
I have never had crashes with previous versions of VDJ ever before
Thanks for such great software.
geposted Thu 18 Nov 21 @ 12:41 am
Important to add: i was using Beatport Link for my musical source for both crashes.
I had another crash, similar circumstances today but was not searching for a song.
While playing BP LInk and performing a screen grab, VDJ crashed.
geposted Fri 19 Nov 21 @ 11:53 pm
Sure I read in another thread a couple of days ago there's a problem with the Beatport DLL.
geposted Sat 20 Nov 21 @ 1:20 am
Try to remove beatport7_vdj_x64.dll from Documents\VirtualDJ\Plugins64
geposted Sat 20 Nov 21 @ 8:05 am
Seems like a good plan, except I'm paying for Beatport Link.
Is VDJ and/or Beatport collaborating on a fix? should I contact BP Support?
Thanks.
geposted Sat 20 Nov 21 @ 9:38 pm
remove it and a replacement file will be created.
geposted Sun 21 Nov 21 @ 12:40 am
thanks. seems like it worked during an hour long session.
geposted Sun 21 Nov 21 @ 6:54 pm
