The echo effect does not work at all with the newly released version of VDJ
geposted Fri 19 Nov 21 @ 10:37 pm
dont waste your time they swear nothing is wrong with the echo....but it continues to get worse and worse....
geposted Sat 20 Nov 21 @ 3:40 am
Nothing changed with echo, so if you feel there's something wrong please do provide more information.
Best to use the cog or '+' on the skin to open the full effect panel to check if all settings are set correctly.
geposted Sat 20 Nov 21 @ 8:03 am
