Hi, after the latest VDJ software update to my N96 controller isn't working with VDJ. Any ideas?
geposted Fri 26 Nov 21 @ 5:41 pm
Sorry, I meant my NS6 controller. I've looked on the Numark support site and there's nothing there to suggest it might causes issues. Any help would be much appreciated, thanks
geposted Sat 27 Nov 21 @ 11:59 am
geposted Sat 27 Nov 21 @ 12:00 pm
Have you installed the Mac driver from https://www.numark.com/product/ns6 ?
(probably the v. 3.3.11 if you are on Mac)
If you have, what exactly is not working ?
You have no control from the NS6 ? E.g. you move the pitch fader but the BPM is not changed ?
You have no Audio output ?
Do you see the controller in MAPPING tab of VirtualDJ Settings along with the keyboard ?
geposted Sat 27 Nov 21 @ 2:11 pm
Installed the driver and now it's working perfectly, thanks so much. I didn't think Numark were releasing any updated drivers for the NS6 as it's quite old now ( 10 years)
geposted Sat 27 Nov 21 @ 3:38 pm
