Hello folks... Sorry if this is a novice question... But in VDJ2021, I don't want the computed stem overlay to show up on top of the default song waveform... This masks the various breaks in the track.. Is there a way to disable that in the display when I load tracks ? Pics below are taken from VDJ 2021 and VDJ8 respectively, with and without the stem shaded over lay... Comparing the two, you can clearly see the difference in the waveform....
TIA.
![](/img/348854/70915/WaveforeWithStemOverlay.jpg)
TIA.
![](/img/348855/84220/WaveforeWithoutStemOverlay.jpg)
geposted Tue 07 Dec 21 @ 9:50 pm
Darnit! I knew it was a novice question!! You have to go into Interface options under skins and select colors instead of shapes ! Duh ... Sorry for the inconvenience :( Oy maybe it might help another novice like myself...
![](/img/348857/56892/Waveform_Option.jpg)
geposted Tue 07 Dec 21 @ 10:04 pm
