Topic: Virtual DJ 2021 - remove panel(s)?
Is there a way how to remove some panels from the Pro view? Namely, I would like to hide FX, User and Loop panels. I assume it is possible with a custom skin (am I right?), but is there some other (simpler) way?
geposted Fri 17 Dec 21 @ 11:49 am
No, you can toggle what information those panels show, but you can't remove them completely.
With a custom skin, almost everything is possible, but it may be overwhelming for users without any experience or some XML / coding background.
However, if you're willing to give it a shot, there are plenty of threads on how to make basic modifications on the default VirtualDJ skin.
Another option would be to find a custom skin that suits your needs better. Most of the popular skins offer plenty of customizations and it is possible to select what's visible and what not.
geposted Fri 17 Dec 21 @ 12:15 pm
