Have you guys checked this out? There is a selection in the settings for Standard, Fuzzy and Fuzzy Full for the harmonic key column.
Read the explanation at the bottom of this screenshot, it may be useful for you.
Look at the √ in the harmonic key column, there is 5
The same image after setting to Fuzzy Full, there are now 9 √ in the harmonic key column
You just have to make sure your harmonic key column is open wide enough to show the √
You could also add the Key Difference column for more detailed info.
Cheers
Cheers
geposted Tue 04 Mar 25 @ 2:20 am
Electronic Green Room wrote :
Is there a script verb that gives returns the key diff...
No such verb, you'll just have to brute force all possibilities.
geposted Tue 04 Mar 25 @ 3:53 am
