OK, so I do a recurse of the folders I want to search in, say, for example here "Tim Reaper". I type in Tim Reaper into the search bar and the correct search results are displayed. Then there's a break, "Other folders" are listed and tracks that have been moved from old folders (that have been deleted and the recycle bin then emptied) are on display. Everything above is correct - i.e. the folder selected to search.
This creates duplicates which, when dragged to virtual folders obviously will not play when doing a live mix as there is no folder to play them from.
The second image where I've highlighted the folder on the Tag Editor actually doesn't exist!
Is there a way to 'clean' up old non-existent files like there was in much older versions of VDJ?
geposted Mon 03 Jan 22 @ 11:44 am
You need to clean up your database as well.
Click on the browser tools button (the round button on the left of the browser) and Select Database->Remove missing files from searchDb
geposted Mon 03 Jan 22 @ 12:38 pm
That fixed it. Thank you!
geposted Mon 03 Jan 22 @ 1:00 pm
