Is there a simple way to invert/reverse the "light on" action of a custom button?
I have a few custom buttons that work flawlessly, and would love the lighting of the button to be reversed.
geposted Sat 29 Jan 22 @ 1:11 pm
Just include on/off on your script action like this:
Original mapping:
Inverted lighting:
Original mapping:
slip_mode
Inverted lighting:
slip_mode ? off & slip_mode : on & slip_mode
geposted Sat 29 Jan 22 @ 1:14 pm
or/also
slip_mode & param_invert
geposted Sat 29 Jan 22 @ 1:43 pm
Thank you Phantom and Locodog for the quick replies.. and love both of the tricks ... cool !
The scripts that I wish to change the light action for are.... let me give you an example.
Button to reset all gain to zero for all decks.
this custom button is ON when everything is as it should be, and OFF when it needs attention. Would like it to be ON when one of the gains is Non-zero to draw attention to it.
is there a way to reverse this lighting action simply, without taking into account all the 4 factorial possible combinations?
The original script works perfectly and simply, only, with lights reversed... Light is ON when all decks are have zero gain, and OFF if any one of the gains is non-zero. The logic is right, and lighting is reversed.
and attempting to reverse the light action with the suggested methods, results with logic that I do not want.. Light off unless ALL 4 decks have non-zero gain. Would like the light to be on if any one of the decks is non-zero.
Maybe I should just get used to the the light on .. and know that I need to do something when its OFF.
deck all gain 50%
geposted Sat 29 Jan 22 @ 1:58 pm
param_equal `deck 1 gain 50% && deck 2 gain 50% && deck 3 gain 50% && deck 4 gain 50%` 1 ? off : on
geposted Sat 29 Jan 22 @ 2:13 pm
wow ! thank you Locodog.. very clever .. woot !
You Rock !
You Rock !
geposted Sat 29 Jan 22 @ 2:24 pm
