Hi all, I am new to Virtual DJ and also a fairly new kickboxing instructor at a gym. For my classes, I've been using some pre-made mixes from commercial fitness music companies but I'd love to mix my own purchased music (mostly because I am not a huge fan of the pre-mixes). For my purposes, the auto-mix feature works really well, but there is one thing I haven't been able to figure out (even after watching tutorials and searching). Most of my tracks are somewhere between 140 and 170 BPM, but to have a good class flow I need them all to be around 160. I've picked songs that I know work well when sped up/slowed down a little. I can speed up a single song but I haven't been able to figure out how to adjust the tempo for all my tracks for the entire auto-mix playlist :( Do I have to adjust the tempo first, save them, and then add the tracks? Or can I load them all into the auto-mix list and somehow set the BMP for all upcoming tracks to 160? Sorry if this seems like a really easy question, and if this has been answered somewhere else please let me know. Thank you very much in advance!
geposted Sun 06 Feb 22 @ 11:02 pm
I think you can use autoBPMMatch in the settings/automation for that.
geposted Mon 07 Feb 22 @ 5:41 am
I tried but it doesn't keep the BPM :(
geposted Mon 07 Feb 22 @ 1:07 pm
I'd suggest that VDJ isn't the best tool for the job. It's primarily designed for DJs to perform live.
For your particular requirements, something like this would be more suitable:
https://www.mixmeister.com/express.php
geposted Mon 07 Feb 22 @ 6:09 pm
@cyndera,
You can also try with the settings/automix automixMode on 'force fade' and settings/automix autoMixBeatMatchOnFade on 'yes'
By the way, everything you run is completely recorded in the History, which can be found under the Lists and advice tab.
geposted Tue 08 Feb 22 @ 6:31 am
Yeah you are right, I can't find the option to lock the BPM on Automix.
Might be a good idea to implement that option in the future.
geposted Tue 08 Feb 22 @ 8:45 pm
