How to get all the "year" data from mp3 tags and store them in the VDJ database? Any batch, or external VDJ database manager?
geposted Sun 13 Feb 22 @ 4:51 pm
Select all the files, right click then select batch > reload tags
That will update the DB with all the tag info, not just the years.
geposted Sun 13 Feb 22 @ 4:54 pm
But i want update only year info, name, genre and other are correct..
geposted Sun 13 Feb 22 @ 4:57 pm
Don't think you can currently do that, it's all or nothing.
I generally make sure my file tags are all correct then import to VDJ as a whole.
geposted Sun 13 Feb 22 @ 5:01 pm
MP3 Tag
https://www.mp3tag.de/en/index.html
Then this step
Select all the files, right-click then select batch > reload tags
Then this step
geposted Mon 14 Feb 22 @ 11:05 am
