Is there a way to make the waveform display go away. I don't need the big audio waveforms scrolling across or up/down the screen. I use DVS and waveform just take up useless space on the GUI.
I should be able to resize them to a very very small display. The Deck waveforms can stay, make the scrolling waveform go away.
geposted Sat 26 Feb 22 @ 12:59 am
I can make that skin edit. Which skin are you using?
geposted Sat 26 Feb 22 @ 7:18 am
