Hi all, I’m having an options problem. I have lost the ability to stab (gate) the sampler pads, I press them and they play to the end of the sample.
What is the setting to enable the Gate (like the hot cue gate) feature.
Thanks, Dave.
Thanks, Dave.
geposted Sun 13 Mar 22 @ 12:53 pm
Try setting the trigger mode to "Hold"
geposted Sun 13 Mar 22 @ 1:07 pm
Hi Klaus, thanks for that. I always forget about the ‘“dot” menus. Tried to search the option and found nothing.
Thanks again, Dave.
Thanks again, Dave.
geposted Sun 13 Mar 22 @ 1:16 pm
easiest to set as Klaus has shown.. but can set in options, with samplerTriggerMode
One can add a script to the keyboard ONINIT, to set the that setting, as one prefers.. so to not be surprised in the heat of the moment, when the trigger mode is not as expected.
for example:
setting 'samplerTriggerMode' "hold"
for example:
geposted Sun 13 Mar 22 @ 1:49 pm
Can change sampler playback mode quickly at the dedicated button for it as well
geposted Sun 13 Mar 22 @ 2:09 pm
