Topic: Customizing the tempo sync'd instrument loop pads?
Hi all,
Sorry in advance if this has been covered somewhere before!
we have as defaults:
Kick / KickHard / KickSnare / KickClap...
Hi-Hat1 / Hi-Hat2 / Hi-Hat3 / Hi-Hat4
Synth1 / Synth2 / Synth3 / SynthMelo
I was hoping I could swap out / modify the set of loops that are there with my own.
Is there a way to customize these / program them / append to the set so I don't lose the ones I want?
EDIT: I figured out if you record the "samples" from the deck output / master inside the VDJ software, then when you drag and drop the recorded sample it will be tempo synced. I was originally confused because I was dragging in samples of known BPM from outside the software into the sampler.
geposted Fri 18 Mar 22 @ 12:19 am
geposted Fri 18 Mar 22 @ 12:39 am
Hahaha thank you I just realized if you record inside VDJ the tempo info goes to the right place. Thanks so much.
geposted Fri 18 Mar 22 @ 12:47 am
locodog wrote :
http://www.virtualdj.com/manuals/virtualdj/interface/browser/sideview/sampler.html
damn I also just found the sample editor now I feel silly.
geposted Fri 18 Mar 22 @ 12:50 am
