- VirtualDJ Forum
- VirtualDJ Technical Support beatgrid not aligned correctly -->
Hi,
I'm using VDJ to prep my files and playlists. I set the beatgrids right, add hotcues (to be exported as both hot and memory cue) etc. When using the VDJ export in my CDJ or RB, I notice that the cues are at the right place, but that the beatgrids are misaligned.
geposted Sun 20 Mar 22 @ 5:14 pm
Works fine here.
Does it happen on all tracks for you ? Or on some of them ?
geposted Mon 21 Mar 22 @ 9:55 pm
It's ok now
geposted Mon 06 Jun 22 @ 5:07 pm
I've the same issue, how can i solve the problem ?
Many thanks
Alex
Many thanks
Alex
geposted Mon 08 Aug 22 @ 2:34 pm
No one have this problem ? I've try with different pc and different db
geposted Tue 16 Aug 22 @ 4:33 pm
