Topic: Audio for Podcast
I'm trying to do a Podcast and I got my microphone to work but I can't get the music to play. You can hear the music through the microphone but if I turn the microphone off you can't hear the music.
geposted Wed 23 Mar 22 @ 1:38 am
What is your gear setup and sound setting in VirtualDJ?
Perhaps you have set a "Record" entry in VirtualDJ to microphone? (record entry in sound setting, will record that sound only)
What setting does my mic need to be on in order to be heard and music work properly?
That depends on where the mic is connected. Assuming its a "basic" computer microphone (connected directly to the computer), then do as the link below : https://virtualdj.com/manuals/virtualdj/settings/audiosetup/microphone.html
(and remove any record entry in VDJ sound settings if you have this added)
