I'm a Visual DJ, trying out TIDAL' s trial period. In theory, streaming music is good. But when I mixed it with others, TIDAL tracks were too thin sounding. Is there a work around?
geposted Sat 02 Apr 22 @ 10:04 am
Are you using autoGain?
I just testes with a track I had locally in a specific version (ZZ Top - La Grange - 2005 Remastered Version), and compared it to the same Tidal track. The local one is 320 kbs mp3, and the Tidal one is Flac lossless
My local tracks is a lot louder when I load them both and mix between them without autoGain enabled
But as soon as I enable autoGain before loading the tracks, they sound the same
geposted Sat 02 Apr 22 @ 1:23 pm
