VDJ will see a controller that hasn't been officially added yet? Can I configure it myself in mapping ? Or in addition to mapping in the VDJ itself, do you need to add code to the program?
geposted Fri 15 Apr 22 @ 11:21 am
No it won't see a controller that is unsupported.
Which one is it you are asking about?
geposted Fri 15 Apr 22 @ 11:26 am
For very basic midi controllers with just buttons and sliders you can map them directly from within the controllers tab in options, the same way as you would map a keyboard.
For anything more advanced with led feedback, jog wheels and maybe special types of sliders you need to create a definition file first:
https://www.virtualdj.com/wiki/Controller%20Developers.html
geposted Fri 15 Apr 22 @ 11:35 am
