I use the Denon MC 7000. When I run a beat loop through the sampler, the loop is permanently on the headphones. Can I turn this off? I use the default 1+2 Master 3+4 headphones. There is only one button for sampler up and down but no cue for headphones.
geposted Tue 19 Apr 22 @ 7:17 pm
by any chance to do you have the sampler output set to headphones only?
To check, use the menu dot on right top of sampler window and then open the "Audio Output" menu
Or check in settings:
samplerOutputDeck -1 is headphones only
samplerOutputDeck 0 is Master (default)
samplerOutputDeck 1 is Deck 1
etc
etc
geposted Tue 19 Apr 22 @ 7:32 pm
-----> Options,
----->Sampler,
----->samplerHeadphones
(Sampler can be heard in headphones)
----->Sampler,
geposted Tue 19 Apr 22 @ 10:23 pm
