Topic: Mapping : How to light on/off a button ?
Hello,
Do you know the command to light on/off a button when it's pressed ?
I checked on the wiki I didnt find anything.
In my case, I own a numark mixtrack platinium fx. When you push the button "flanger" it become red.
I assigned this button to another command. The command works, but the button is not lighted anymore when we press on/off.
Do yo have any idea ?
thank you
geposted Thu 12 May 22 @ 11:37 am
It depends if the command you use can be validated as true or false (which is often on or off)
Hello,
I use this mapping, because I want to use the crossfader live with the 4 channels.
FX_HPF : deck 1 leftcross
FX_ECHO : deck 3 leftcross
FX_Flanger : deck 2 rightcross
FX_Phaser : deck 4 rightcross
I want to see when a crossfader is activated or not
I tried for exemple : deck 1 leftcross ON
But there is still no lights on the buttons when it's activated and desactivated.
When I push the button FX_LPF, just to see a standard behaviour, I can see :
- When I hold the button it send "ON"
- When I release the button it send "OFF" by default
Which controller is that ?
Depending on the controller firmware it may not be possible to control these leds directly, or it may not be possible to control all of them at the same time.
I found the solution !
I just edit this part :
LED_FX_HPF : deck 1 leftcross
LED_FX_ECHO : deck 3 leftcross
LED_FX_Flanger : deck 2 rightcross
LED_FX_Phaser : deck 4 rightcross
Hi phantomdeejay
it is numark fx platinium mixtrack =)
