Hi all.
Hoping someone can help. I just downloaded Virtual DJ onto a new Windows 11 laptop.
I have managed to get my iTunes library to be recognised in the folder window, with all my playlists, and I have ensured that I have tracks downloaded to the folder on the laptop.
However, when the iTunes folder is selected, no music tracks appear in the track list window next to it.
I have checked, and the media is in the folder. I have also made sure that iTunes is set to share its .xml library file with other apps.
geposted Mon 16 May 22 @ 6:33 pm
So, iTunes Playlists are present under iTunes folder, but empty when u select one in VirtualDJ ?
geposted Mon 16 May 22 @ 6:37 pm
Yes, exactly
I'm confused
I'm confused
geposted Tue 17 May 22 @ 8:57 pm
