I use the action browser_window 'folders,songs,sideview' as custom button and pad button to switch between the browser windows. It's essential for using VDJ by keyboard or controller.
Since Build 6959 this Funktion is broken. Only browser_window +1 or -1 switches between folders and songs, not to sideview.
In Build 6921 the action browser_window is fine and works as expected.
Is a new syntax used or is a workaround possible?
geposted Sat 28 May 22 @ 6:49 am
Indeed a bug, will be fixed in next update
geposted Sat 28 May 22 @ 7:26 am
@adion
Thankyou very much ;)))
I have checked it all Versions of Build 6969 (VDJ2021,VDJ2020,MAC) on Intel,AMD,Apple Silicon.
Works on all my computers as ever.
geposted Sat 28 May 22 @ 3:24 pm
