I use folders with shortcuts for mp3 files (* .lnk) for my favourite songs. But now are all of these folders in the VDJ browser empty. Why? It was working many years...
geposted Sat 28 May 22 @ 11:28 am
Can you try with EA update 6969?
geposted Sat 28 May 22 @ 11:34 am
just download and tested v8.5-64 b6969 , folders are still empty :-(
Before you fix it, can you give me a link to the latest built where it still worked? I need this feature tonight.
edit: Ok, I'm back to version 6921, it still works there. :-)
geposted Sat 28 May 22 @ 11:39 am
If you do not have (or ever need) the link, to all Older Builds of Virtual DJ:
https://virtualdj.com/download/build.html?showall=1
geposted Sat 28 May 22 @ 1:21 pm
Should be fixed in build 6972
geposted Tue 31 May 22 @ 7:08 am
I have same problem.
In older versions of Virtual DJ playing mp3 files via windows shortcuts worked. It doesn't work in newer versions. I am currently using the VirtualDJ 2020 pc build 7059.1902 and the program still does not see these shortcuts despite the fact, that you wrote above, that it will be corrected from build 6972.
geposted Fri 09 Sep 22 @ 1:32 pm
I never use LNK/Shortcuts before so I was curious and tried it and it WORKED.
Still, I won't be using this method (why create another un-necessary file)
v8.5-32 b7131
v8.5-32 b7131
geposted Fri 09 Sep 22 @ 7:09 pm
I test it right now,
before i setup the fileformat in the setting with ",lnk"
now it works for me.
geposted Tue 27 Sep 22 @ 6:29 pm
HardyHardwich82: Thanks for the tip.
I looked for the option you indicated in the settings, added the ".Ink" extension and it worked :-)
I did not know that something needs to be changed there. In the earlier version of Virtual Dj I was using, it was apparently set natively / by default.
geposted Tue 04 Oct 22 @ 8:18 pm
