Hi,
On the early version BUILD 6954 (2022-05-23) the changelog includes:
-improve multi-bpm detection boundary detection when experimentalBeatAnalyzer is on
Does that mean multi-bpm analysis could be batch folder mode (multiple tracks simultaneously)?
geposted Tue 31 May 22 @ 12:29 pm
The change is only related to how well the boundaries between parts with different bpm are detected when experimentalBeatAnalyzer is on and a track is scanned for multiple bpm's.
Normally this is still done from the bpm editor as before, but you could also use a custom button and assign it to
When you select multiple files in the browser and use this button they will all be re-analyzed using multi-bpm scanning.
browsed_file_analyze multi
geposted Tue 31 May 22 @ 2:01 pm
Thank you very much Adion.
And, please, what about "-Fix pitch bend on controllers with motorized jog wheel"? is it related to the motor hid commands or with dedicated buttons on this devices or controllers?
Regards.
Regards.
geposted Wed 01 Jun 22 @ 5:34 am
The fix is for both manual corrections using the platter and using the pitch bend buttons on the controller itself.
geposted Wed 01 Jun 22 @ 5:58 am
