Hello VDJ Fans
Can anyone tell me the exact mapping code action for the COLOR_FX_PARAM please?
I've done all the ground work updating software, drivers and firmware but when I turn the knob on my controller DDJ800 nothing happens.
If I use the mouse on the software interface it works but not at the controller.
Any help will be much appreciated.
Thanks
Thanks
geposted Sat 25 Jun 22 @ 10:15 am
You have to map with effect_slider by assigning the number of the specific knob you want to control (opening the effect gui can help you understand) but above all in the command you have to specify that the action must be performed on the colorfx. I have mapped the knob in the RZX and control everything perfectly.
geposted Sat 25 Jun 22 @ 1:35 pm
If you have remapped your device, then you can always select "factory default" mapping (you won't loose your custom mapper) and check what each key does on factory default.
Then you can switch back to your custom mapper and adjust anything you need/want.
Finally keep in mind that COLOR_FX_PARAM knob works in conjunction with COLOR_FX_SELECT_XXX keys.
In other words you need to select one of the 4 COLOR EFFECTS first before turning the knob has any result.
geposted Sat 25 Jun 22 @ 2:19 pm
