Topic: how to stop prying eyes!!
birty1PRO InfinityMember since 2010
More and more people think the PC is their property and want to look, to see what is next and even scroll!! ...is there anyway to blank the screen with a logo on a hot key?
geposted Tue 05 Jul 22 @ 1:53 pm
No but you can lock it with the standard Windows Ctrl+Alt+del then enter
geposted Tue 05 Jul 22 @ 2:21 pm
I suppose it's that well oiled lady who would like you to "play something good"? She was in my place last week.
geposted Tue 05 Jul 22 @ 3:54 pm
Dunno about PCs, but, on a Mac in the screen saver settings, you can setup "hot corners". I have a corner where moving the mouse cursor into the corner triggers the screen saver. It has a message asking for "Touch ID" or "Enter password" and also a message that "CCTV recording is in progress". Handy if you need to step away from the computer.
I have a boot camped Mac with Windows 10, I've had a look but I'm not familiar with the PC settings.
geposted Tue 05 Jul 22 @ 4:29 pm
Windows can be set to the lock screen, with key combo:
WinKey + L
and then unlocked with your PC's password.
geposted Tue 05 Jul 22 @ 5:23 pm
