Topic: Logo plugins show upside down,wack!
man..I am trying to replace the vdj logo on the cut logo and slide logo my own logo (BTW the SBDJ versions as well as the new cut and Slide "tag" on to the same image)..but the logo its either upside down or "mirrored"..i then edit the image to be upside down on my Logo maker software but still..and yes..I'm running windows 7 on PC..whats gives?
geposted Tue 19 Jul 22 @ 5:54 am
djcelPRO InfinityModeratorMember since 2004
I guess you use a version of the plugin made for old VirtualDJ versions (7 and before if I understand well your issue)
geposted Thu 21 Jul 22 @ 6:03 am
