So the classic echo out to a brake, used when you're switching genres, or just want to switch up the BPM by such a large amount you're not going to bother to beat match.
How do I set it up to work in VDJ?
If you don't use it, what effect / transition do you use when you're changing genres / bpm to smooth out the change?
geposted Sat 23 Jul 22 @ 11:52 am
There are addons called BrakeFX and BackSpinFX that are perfect for this. I use them constantly. I believe they ship with pad pages that give you a great starting point.
geposted Tue 26 Jul 22 @ 6:45 am
