I am aware that some issue has been recognised with AMD and stuttering problems, however i just can't get this issue on Rekordbox, but always get it on VDJ. I have several colleagues with same processor all on Rekordbox and same have no issues. Are VDJ aware of issue?
geposted Mon 01 Aug 22 @ 8:29 pm
I am following this post for answers, because I have exactly the same problem
geposted Mon 01 Aug 22 @ 8:43 pm
is the latency set the same on both softwares?
and are you testing with the same files on both
geposted Mon 01 Aug 22 @ 9:46 pm
Yes identical folders same music, this has got more noticeable recently and i have noticed more VDJ users having same issue.
geposted Mon 01 Aug 22 @ 9:50 pm
and the latency?
geposted Mon 01 Aug 22 @ 10:14 pm
yes have tried latency at different levels currently on 256. I am confinced this is some conflict with chip and vdj, just look on facebook groups or google it, vdj users having the issue, none appear to have it with other software, Rekordbox for one.
geposted Mon 01 Aug 22 @ 10:25 pm
interesting, i have AMD Ryzen 7 too and have stuttering issues very often
geposted Mon 01 Aug 22 @ 10:27 pm
Try Rekordbox see if you get it, i think you will find you don't, be interesting to find out .
geposted Mon 01 Aug 22 @ 10:29 pm
Which controller or audio interface are you using?
There are no known problems specific to AMD processors.
geposted Tue 02 Aug 22 @ 5:01 am
DDJ-1000 controller-vdj (latest update) tried on win 11 and win 10 . If no problems, why are so many having the issue? AMD have known issues, with fTPM Enabled , but the weird thing is nobody seems to get this stutter/pause on Rekordbox, all reports are using VDJ that i have seen?
geposted Tue 02 Aug 22 @ 8:46 am
No idea who these 'so many' are, yours is the first post i see on the forum about problems with AMD processors.
No problems personally either with AMD Ryzen 5 here.
Did you try if changing the latency to 512 makes a difference?
Did you try LatencyMon to see if it's a specific driver perhaps causing issues?
geposted Tue 02 Aug 22 @ 8:50 am
So you have not read comments above? Googled it? https://www.google.com/search?q=vdj+stutter+AMD+Ryzen&oq=vdj+stutter+AMD+Ryzen&aqs=chrome..69i57j69i60l3.7438j0j4&sourceid=chrome&ie=UTF-8 Many are having it, look on Facebook groups too.
geposted Tue 02 Aug 22 @ 8:54 am
Another
geposted Tue 02 Aug 22 @ 8:56 am
Another
another , trust me many are having the issue with VDJ
geposted Tue 02 Aug 22 @ 8:58 am
Yes I have gone higher than 512 latency too.
geposted Tue 02 Aug 22 @ 9:03 am
Since you compared to RekordBox, did you try to set mathEngine to disabled?
Also, which exact CPU model do you have?
geposted Tue 02 Aug 22 @ 9:04 am
Processor
1x AMD Ryzen™ 7 5800H Processor(Ryzen™ 7 5800H)
Memory
1x 16GB DDR4 3200
all music on internal Evo m.2 drive
Legion 5-15ACH6H Type 82JU
No not disabled math engine but surely this spec machine should handle that?
Memory
1x 16GB DDR4 3200
geposted Tue 02 Aug 22 @ 9:08 am
It should be, but it will be easier to find the problem by eliminating it as the cause of the issue.
The laptop uses the AMD's integrated graphics?
geposted Tue 02 Aug 22 @ 9:17 am
No it has a NVIDIA GeForce® RTX 3070 8GB
geposted Tue 02 Aug 22 @ 9:19 am
