i want to dj and play my midi keyboard live all running off my laptop...
i was wondering if there is an advised way to make it happen with virtualdj....
or how do you do it??
dj controller will be connected via usb and so will m audio oxygen pro 25 keyboard..
this little setup will cost me a bit.... i want to get it right hahahah!
thanks in advance
thanks in advance
geposted Thu 04 Aug 22 @ 6:34 pm
If you don't want the keyboard to control VDJ, like because it's controlling a virtual instrument running on your laptop at the same time, then you set VDJ to ignore it in he mapping settings
If you DO want the midi keyboard to control VDJ you can map it to do so. There is an example below I did a while ago
But it will of course not be like playing a virtual instruments like a piano, because VDJ is not - it's a live DJing software. So you will be using your midi keyboard to DJ - not play the piano (or any other instrument)
geposted Fri 05 Aug 22 @ 10:16 am
